If I understood your testing procedure I might be able to add more insights. But, if you are driving for utmost fuel economy that would mean you deliberately avoid steep transients (rapid rpm changes). A product like Pulstar is going to give greater returns through transients than at steady state. This still does not answer the question of concerning your testing. Is there a standard test procedure your group uses?
