Old 06-19-2015, 07:11 PM   #8 (permalink)
Lectrik
Originally Posted by thingstodo View Post
I have 0.00 ohms on that link. So that should not be the problem.
Looking at the board under the magnifier ... I am pretty embarrassed by the re-soldering that I did. It looks like pin 1 on U4 is a cold solder. Perhaps I should go over the board again with a soldering iron and try to make it a bit more of an example of what you SHOULD do instead of the present state - an example to AVOID.
It's been years since I soldered anything ... but it should come back with practice!
Follow the schematic and check continuity between a questionable connection and where it goes to. I found two open circuits where a pad should have been on the board.
The Following User Says Thank You to Lectrik For This Useful Post:
thingstodo (08-28-2015)
