Who- what you described sounded like a soft field takeoff rather than a short field one. But you're right about the way you have to push pretty hard to keep the nose level.
Anyways Metro, the reason ground effect increases performance so much is because it significantly reduces induced drag and thereby reduces the angle of attack needed to create enough lift (or vice-versa depending on your view).
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
