Old 07-06-2015, 09:49 AM   #4 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
It seems that there's something wrong with transistor running current to the backlight.
It's easy to chech if you'll connect LED backlight with 330 ohm resistor to +5V it should be stable. If not it means that there's something wrong with your LCD display. If everything will be ok with resistor, there's something wrong with connection between Arduino and LCD. There's resistor, and transistor only so not hard to find the reason.
And one more question - are you sure that you connected backlight signal to digital 9 ?
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
