Old 07-20-2015, 10:20 AM   #433 (permalink)
apowers
apowers's Avatar
Hi everybody,
I am having a strange problem with my display. The problem is with the charging screen. After about 1 1/2 hours of charging the light stops and the charging time display goes to zero, and SOC display goes to zero.
The charging amps stays on. After the charge is finished and the display is back to the other screens the SOC has been updated to the point where the charging screen malfunctioned. This has happened during the last two charge cycles. Our temps around here are in the high 90's and high humidity.
Since the temps are so high I only charge very early in the morning. About 80 degrees.
Any suggestions are appreciated.
Thanks Alvin
