Old 01-10-2008, 09:41 PM   #5 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
use cardboard and masking tape to reinforce it if you make a large part. Just make some narrow 1/2" strips of cardboard or paper internally to help it hold it's shape better. Once you get it formed you can sand it carefully then cover it with a layer of lightweight fiberglass body filler then paint it.
I have patched body panels on cars like that and it actually works really well. You can use a high speed sanding wheel to shape the foam a bit lower than you want it then cover it with fiberglass body filler. Smooth the filler like any other body panel then you can paint it and it is perfect looking.
Also it is nearly impossible to keep the nozzle clear after you use it so once you start using it, make all the parts you want. It will probably be clogged up next time you go to use the can
My Convertible Metro XFI Plug in Hybrid Project build log
