Old 07-30-2015, 02:57 AM   #24 (permalink)
oil pan 4
I started 6 branches, might add a 7th, then attached 30 feet of 1/4''OD PVC tube on my 13x22 inch bottom pad.
I am sure I will get at least 30 to 50 more feet on there.
Also might extend the pad several more inches for under leg cooling.
Shouldn't be too difficult to get that uncomfortable cooling I am after, I can always turn it down from there and you cant use cooling capacity that you don't have.
