Old 07-30-2008, 04:53 AM   #11 (permalink)
crexcrex
Meemooer can probably tell you if it is a diffuser pan or simply vg's. I personally suspect that they are vg's..............the diffuser pan applies downforce and does away with spoilers and down force, i was previously informed down force does not make for ecomodding.............lets hope that meemooer is reading this and can correct us both.
I do know that i have seen vettes with those expensive addons and they were indeed pan diffusers. Pretty pricey stuff might as well put lead into the trunk.
