Old 01-10-2008, 10:53 PM   #3 (permalink)
newtonsfirstlaw
The Mighty Mira - '92 Mira
90 day: 61.32 mpg (US)
Originally Posted by AndrewJ View Post
That's awesome!
That thing was really hauling if it was doing that kind of speed. I doubt it really had a 1-2kw motor in it though. Maybe 1kw max, the aerodynamics would really cut back on the amount of power it takes to get up to those speeds. If a HPV can hit +60, and a human cyclist can put out 500watts in a semi-sustained effort, then I think you could easily get away with a 500watt motor and do those kind of speeds in a adequately streamlined vehicle.
Yes, I suspect that you could easily get away with a 1kW motor in there, depending on the velomobile. With the WAW, it should take almost exactly 1kW.
e.g. 250W * (80/50)^3 = 1.02kW That's for 50mph, or 80kph.
I have the feeling that within a couple years these things are going to be EVERYWHERE.
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
