Old 09-01-2015, 02:57 PM   #4 (permalink)
freebeard
This is a great idea. My request is that you consider a geodesic construction. It can be laid out as a flat pattern with darts and cut from a single sheet. That will self-assembly into an accurate surface. Much less work.
http://starship-enterprises.net/files/3f%20icosa%20Peel%20Pattern.jpg
I can provide all the relevant edge lengths for a prolated ellipsoid.
'What do you think, sirs?'
Last edited by freebeard; 09-01-2015 at 03:07 PM.. Reason: swapped out example for smaller size
aerohead (09-01-2015), BamZipPow (09-01-2015)
