Old 09-01-2015, 04:43 PM   #6 (permalink)
aerohead
16-mods
The list is at home but here goes:
*reworked airdam with belly and edge radius
*grille plug
*improved cooling ductwork
*reconfigured hood blister,widened out to edge of A-pillars,with NACA submerged-inlet /ventilation duct-to cowl inlet
*faux GTP full-compound,triple-curvature windscreen
*faux 'active' windshield wiper cowl area fairing
*new mini-mirrors
*mirror delete
*faux flush glass
*tape all seam and cut lines
*full gap closure between cab and bed
*restore missing belly pan section
*add belly pans to lower A-arms
*add urethane pan sections around rear axle gaps
*faux 'active' wheel fairings(before and after front wheels)
*ditto rear wheels
*lowered diffuser addition to boat tail (2.8-degree)
*add blended flow fence into lower perimeter to close in Coke-bottling
*lower rear skirts to former full depth and add integrated flow fence
*reconfigured aeroshell
*reconfigured boat tail
*reconfigured boat tail stinger (full-length)
*simulated suspension drop (deflate the tires)
Looks like I'm at 23 things to test,plus the model.
aardvarcus (09-01-2015), BamZipPow (09-03-2015)
