The question to be answered by my following aerohead's dimensions would be the difference between a pointed tail like The Template and a rounded tail like the Dymaxion.
Truncations are do-able. Or one could add a strap-on cone, while [re-]considering the fineness ratio.
The larger question is the effect of creases in the surface. A 3v sphere has a break angle of 360/20 or 18°. A prolated sphere will be sharper at the ends and smoother in the middle, with the limit case being a compound curve. I want to see if there's any 'dimple' effect with the lower frequency. A 2v would be about as angular as the F-117.
