I had an '07 Dodge Caliber and it had the same thing. It was almost worthless. It wouldn't shift smoothly and like what was said it wouldn't let you pick the gear you wanted if it was below a certain rpm range. Being able to shift into neutral is much more useful.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
