Old 09-12-2015, 01:48 PM   #8 (permalink)
CigaR007
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
--Active Grille Block--
Here are some details on the prototype Active grille bock:
The systems consists of an arduino UNO board, motor shield and a control panel to activate 2 steppers motors, independently. The vane mechanism is a vent miser, as seen in this thread : http://ecomodder.com/forum/showthrea...ore-29966.html
I took apart the vent miser and kept only the core and added a stepper motor for greater control and torque. A servomotor can also be used and it would provide position feedback, which isn't the case with stepper motors.
I wrote a few lines of code for the arduino+motor shield and it works pretty good.
Arduino Code :
PHP Code:
#include <AFMotor.h>
// Connect one stepper motor with 200 steps per revolution (1.8 degree)
AF_Stepper motor(2002);        // to motor port #2 (M3 and M4)
const int  buttonPin 2;        // the pin that the pushbutton is attached to
int buttonState 0;             // current state of the button
int lastButtonState 0;         // previous state of the button
void setup() {
pinMode(buttonPinINPUT);     // initialize the button pin as a input
Serial.begin(9600);            // set up Serial library at 9600 bps
motor.setSpeed(60);            // 30 rpm
void loop() {
buttonState digitalRead(buttonPin);      // read the pushbutton input pin
if (buttonState != lastButtonState) {    // compare the buttonState to its previous state
if (buttonState == HIGH) {
Serial.println("MICROSTEP steps");
motor.step(50FORWARDMICROSTEP);    //CLOSE GRILLE VANE
delay(500);
    else {
motor.step(50BACKWARDMICROSTEP);   //OPEN GRILLE VANE
delay(500);
lastButtonState buttonState// save the current state as the last state for next time through the loop
Below are a few design sketches and the actual arduino code for the grille block.
Here is a basic overall diagram of the system (still in design):
The Following 7 Users Say Thank You to CigaR007 For This Useful Post:
aerohead (09-12-2015), BabyDiesel (10-02-2015), Cd (09-12-2015), Daox (09-14-2015), iveyjh (09-12-2015), MetroMPG (09-14-2015), Xist (09-16-2015)
