I reduced the Id and Iq down from 300,300 to 200,200, and also made the ramp up more gentle. Just for testing...
I think I may have messed up on the data dump. Notice that the graphs seem to suddenly get bigger in magnitude near the end of each dump. I had been using different parts of a big array for multiple data arrays. I may have made a mistake on something overwriting something else. I'll double-check and send you a correction if necessary. Also, the voltage and current are basically 180 degrees out of phase. That could just be data being written at the wrong offset. AND, voltage and current are the same magnitude. I find that very unlikely... voltage ranges on 0-1500 where 1500 is 124volts. Current ranges so that 4096 means 600amps.
