Old 09-24-2015, 05:02 PM   #2067 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
For the permanent magnet motor, with the encoder I twisted the motor post until it just passed "index", meaning it started over. Then, I ran the motor with Id = some nonzero command
Iq = 0.
Then, let the motor turn until it stopped, and noted the angle from the encoder. Then, I saved that offset for all history for that encoder/motor pair, and then just run the FOC code with Id = 0, Iq = torque command.
The code is all in C, but there's quite a bit of optimizations done, which doesn't make it terribly readable.
A single
long int / long int takes like 25uS or something, so I have to do a bunch of sneaky stuff. I'll send it over to you to see though. The sensorless is ALMOST REALLY REALLY REALLY ALMOST ready to test. so I could send you that one. Just ignore the "sensorless" function. It is out of control. haha.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
e*clipse (09-24-2015)
