Old 09-29-2015, 04:31 PM   #1 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Rarity- Accord V6 6MT Hypermile/Build Thread
This Thread is really long, so here is a table of contents.
42 MPG!
Rear diffuser, wheel boattails, upper grille block, and frondertray.
Tuft test video, scangauge relocation, mid undertrays, lower radiator panel, and rear diffuser extension.
New grille block, new best trip back home, and EOC questions
42.3 MPG!
Rear wheel spats and more undertray panels
43.6 MPG and minor tire spat modification
New best tank, 35.9 MPG!
Engine mod plans
New best tank, 38.1 MPG!
45.1 MPG!
47.1 MPG! Another new record!
Block heater
Exhaust channel deflector and new record tank 38.9 MPG
It was a dark and stormy night...And I got a 40+ mpg tank!
A few months ago I sold my 4 cylinder accord because I found my dream accord, a white V6 6MT sedan with ivory interior. So far the V6 has really impressed me with its mileage, although it was a step down in gas mileage, it wasn't as big as I thought it would be. The V6 has about 84 more horsepower than the I4, 256 more pounds, and an extra gear, the thing I was really looking for. Despite the low city rating of 18 MPG, this thing could probably beat the I4 mileage-wise in a short trip of less than 3 miles from a cold start. I blame the pre-cats.
Since I have a new commute from when I had the 4 cylinder, I can't directly compare mileage, but I have had enough highway trips to compare those. So far I have been getting around 36 mpg, until I adjusted the valves and cleaned out the intake manifold and runners. After the service, the car felt more responsive and about 10 hp more powerful. Then on my next commute i got 40.3 MPG! Best trip in the V6 as of yet! Clean out your intake!
I have not done much modification to the car yet because I’m busy with college and I need more coroplast and ideas, but I have done some stuff. When I first got the car I noticed that it had DRLs, those had to go. I pulled a few fuses before finding the right one, a little 10 amp fuse. No noticed mileage improvement, and a DRL light popped up on the dash, which I can ignore.
The next mod was a grill block, thanks to inspiration from Istas I decided to try to make both upper and lower blocks. The upper block was a failure because I accidentally cut it too short and tried to expose the Honda badge. I have a whole other sheet of brand spankin’ new coroplast, but I didn’t want to cut into it in case I wanted to do a belly pan. The lower block however was a success and I think it looks decent. I thought about putting the hole in the middle, but I wanted to have cooling air going to the A/C evaporator to retain full A/C performance should I need it. The block is attached with six strips of Velcro on each surface: 2 long strips, top and bottom, and little strips on each side of them. The grill block did not raise the operating temperature and I did not notice any mileage improvement either.
After that I remembered the stupid little glovebox light that turns on whenever the headlights are on, so in the interest of reducing electrical load, I took it out.
Planned mods: Wheel covers, Rear wheel skirts, Engine and rear undertray, Hybrid diffuser if i can find one for cheap, airdam, and upper grill block.
Name:	image (7).jpg resized.jpg
ID:	18817   Click image for larger version
Name:	image (10).jpg resized.jpg
ID:	18818   Click image for larger version
Name:	image (11).jpg resized.jpg
ID:	18819   Click image for larger version
Name:	image (13).jpg resized.jpg
ID:	18820   Click image for larger version
Name:	image (12).jpg resized.jpg
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Last edited by Daschicken; 09-05-2017 at 10:04 PM.. Reason: words instead of symbols
The Following 4 Users Say Thank You to Daschicken For This Useful Post:
BabyDiesel (09-30-2015), mcrews (01-24-2016), niky (02-14-2016), UltArc (03-06-2018)
