Old 07-31-2008, 03:48 PM   #5 (permalink)
slurp812
Silver EP3 - '02 Civic Si
I'd be looking for a way to enable the power assist during EOC rather than disable it, assuming it's no more complicated.
EDIT: no ideas about the ABS.
But I do wonder what would happen if you set up a kill switch rather than keying off and back on again. It may be a potential solution to both problems.
Oh and I am working on a kill switch. I am going to try and switch off the fuel pump. its the easiest to get to from inside the car. If I ever get around to it, I will post pics. I actually have a relay to use, and have had the back seat out looking at it. I just need a switch, and some time....
