Old 10-22-2015, 07:55 PM   #22 (permalink)
planejob
BeginnerModder
Originally Posted by planejob View Post
The project is going to stall until October 31. I've got to travel for work and will not be able to fiddle with the spanners.
I fibbed a little, I guess. I still have to study, and travel, but the aluminum plate came in today. I don't have a lot of time to get started on the engine mounting holes but I did set the plate on top of both components, the engine and tranny, to confirm that the plate is the right size.
As I mentioned earlier, I plan to leave the bottom of the bellhousing open to provide access to the torque converter bolts. The adapter plate will line up with the bottom of the engine block -you can see the engine block outline in the paint on the adapter:
The Following User Says Thank You to planejob For This Useful Post:
Daox (10-23-2015)
