Old 10-24-2015, 11:01 AM   #4 (permalink)
BrandonMods
Champagne - '13 Chevy Cruze 1LT
90 day: 33.35 mpg (US)
If it were me, I'd instead focus on programming the alternator to electronically shutdown during normal engine operation, and startup during DFCO. Then I would select an appropriately sized LiFePO4 to replace the inefficient lead acid battery, trying to locate it somewhere within the passenger compartment or under a seat (for better temperature control). You could program the Arduino to re-engage the alternator if the voltage drops below some set threshold.
The trick would be keeping the battery from frying, which might be where a supercap and DC/DC converter might come in to act as a buffer.
This is also a great idea to be explored. The supercap bank would have to be sized appropriately, even over sized to protect the battery. Could a bleed off resistor be used as well in this case?
The Following User Says Thank You to BrandonMods For This Useful Post:
kafer65 (10-24-2015)
