Old 10-27-2015, 05:11 PM   #6 (permalink)
freebeard
It doesn't look like OP was asking about a productized solution.
The specialized tooling required would be a Bridgeport mill or something similar to chuck the disk in and mark the holes at 120°. 64th inch accuracy should be sufficient. Then a flaring tool to bellmouth the holes in the disks. The spiral springs might attach directly, else the flat square mount could.
