Old 11-25-2007, 10:52 PM   #162 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
SW skools me on the basics (I need it)...
Originally Posted by SW
I think that does count. It's the current thing to do.
I don't think jumper cables have enough surface area in contact with the battery cables to handle the current you'd need (even in a test). The clips will probably heat up, and may even burn them at the contact points (you might be shocked to find the battery terminals burned as well), but I may be wrong. Don't let this impede your progress, just keep an eye on it. I read about many EV builders who regularly check and tighten their battery terminal connections because of the effects the high current has on them. One of the advantages of going with higher voltage is lower current:
Volts * Amps = Watts (Watts law)
But you may not be able to change the top voltage your motor/controller can take, so don't get too wired about it.
The other potential problem is the voltage drop across the jumper clips in proportion to the current:
Ohms * Amps = Volts (Ohms law)
So you want to minimize the ohms (unit of resistance) wherever you can: thick cable, heavy duty terminal connections, high surface area connections to your controller, fuse(s), motor, kill switch (eventually), etc. Try to have as little 'etc.' as possible.
