Old 10-29-2015, 07:25 PM   #14 (permalink)
user removed
Suzuki TU250X. I owned one and it will handle the short Interstate part of the commute unless you are over 6 feet and 225lbs. You can also adjust the exhaust valves without removing anything else but the access cover. The intake valve will require tank removal.
regards
mech
