Old 11-19-2015, 01:23 PM   #3 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
I'm looking forward to what you come up with, Tim. The best I can recall from what I know about small block Chevy engines:
-Decreasing tube diameter increases low-rpm exhaust speed, which in turn helps low-end torque through more efficient cylinder scavenging. This *may* lower upper rpm power, but how bad could it be on a 1.0?
-Longtubes are better than shorty or block hugger headers for low-rpm situations (towing, economy).
-Thicker material and/or header wrap will keep heat inside the collector tubes, keeping exhaust speed up for better scavenging. This is for all rpms.
-Port match!
All dyno test I have seen are at WOT. Since we rarely go past 1/2 - 2/3 throttle for short periods and spend a lot of time at part-throttle, this seems to indicate smaller tubes than usual? I think you could go down to ~1" on the collector tubes, since each cylinder is only 0.33 liters of displacement, versus 0.713 liters/cylinder on a 350 SBC.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following 2 Users Say Thank You to BabyDiesel For This Useful Post:
aerohead (11-19-2015), MobilOne (11-20-2015)
