Old 11-25-2007, 10:55 PM   #164 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
More good info from SW:
No I hadn't seen the new evconvert article yet (I check it almost daily), thanks for letting me know.
Non-superconducting wires all have some finite amount of resistance and so will cause some amount of voltage drop across them (proportional to current). This loss of wattage amounts to loss as heat. Note that this wattage doesn't need much voltage when the current is high (ex. 1.88V * 400A = 752W or more than 1 hp).
Somewhere there exists well proven recommendations for the guage wire for a given current. As for voltage, thickness of wire is irrelevant, but thickness of insulation is, but you'll not likely exceed the wires' voltage ratings.
There's no electrical reason not to go too thick with your cables, but at some point it adds too much weight and expense (for both cables and connections). Copper is heavy and I don't recommend aluminum wires. Very heavy cables may also be more diffucult to work with.
