Old 12-04-2015, 02:17 PM   #26 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
While driving a few minutes ago, I thought of something that needed to be added to this thread:
When I deduced the numbers down and got the RRC for my Blacklion tires, they seemed pretty good since they had a value of 0.010. This is right on the line between LRR and normal tires.
Then I remembered - The tires were pumped up to 70 psi for the test!
So! That will throw the numbers off if tire pressure is lower than I tested. I typically run them around 60 psi, so that would mean the RRC is higher than my test. Maybe not now, since my tires have worn down some and "loosened up".
Hmm... makes me wonder what the RRC is if they are at placecard psi (35 psi).
Actually, I think I will test the RRC between placecard psi and hypermile psi eventually. It will be good to have numbers behind what we already know is a benefit.
All in all, the test concludes that I need LRRs... asap!
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
