Old 12-25-2015, 03:05 AM   #19 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Update 6months
While in Las Vegas NV temps were geting over110°f and the plastic relaxed Slightly about 1/4" so I used some "light"tan hammer tone plastic compatible rattle can paint. Painted over the wight duct tape burn hole patches. Figured it would help as sunscreen spf 100. Maby. However much ro my dismay it turned out a dark copper. So during my 2nd trip to LV the heat sag was much larger problem @ about 117°f it would sag about .5" on the 2 center spans at the hottest part of the day. But the plastics would go back to tight after about 1-5min of driving got back to the soggy cool NWand it was back to a snear drum.
Name:	added hammer tone paint in May.jpg
BamZipPow you called it 6months. However the Oratex has been tested past 10years passing FAA testing so it will work for the long hual. Srick and shrink repairable easy compound curves
Hear is a hammer test with the Oratex I found. http://https://youtu.be/yoI5PEIxtEg
Name:	my first uv caused crack next to a burn hole.jpg
Well 6 months in I saw 3/4" crack form in week spots only(over heated cussing it to thin after thickening)
Name:	tube from a 4 in. fat tire bike as a gap filler-1.jpg
May up to pool noodles I didnt account for rhe forward lean of the back of the cab v2.0 will.
The last 2 are learning curve errors
paint chiped off from improper attachment
Name:	paint chiped off from improper attachment-1.jpg
The missing paint(bright spots) was caused by the bace plastic changing to much strechmarks given time theas would become cracks justified an extra 10# of steal fraim work
wasn't melted well enough and separated nextto hot
Name:	wasn't melted well enough and separated nextto hot.jpg
Changes for v1.2
Added 1/2" Millar backed fome between the fraim and plastic. It softened the allmity side to top transition and noise suppression
Added an inner hoop for mounting point.
Added lift struts.
Added a latch mechanism
Added Garage goor seal for bededge seal
Total weight for moving part is 35# V1.0 was 21#
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 3 Users Say Thank You to gumby79 For This Useful Post:
aerohead (12-26-2015), BamZipPow (01-04-2016), deejaaa (12-26-2015)
