01-12-2016, 10:14 AM
#9 (permalink)
Some members block behind the grille opening to keep the OEM look. There may be a small efficiency penalty vs. an external block, but it's still way better than wide open OEM.
Also you might consider a block heater if you've got somewhere to plug in. Depending on wattage, an hour of pre-heat will make a noticeable difference in cold weather.
