Old 08-03-2008, 02:41 AM   #1 (permalink)
Concrete
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph
I drive a 2nd gen S10 (2000) extd. cab and I've got some data on wheel covers
noticed changes in scangauge readings after installing covers
So I went out in search of A-B-A and (~250 miles later) found +1.3 mpg
On ~28 mpg runs - That is about 4-5% - depending on how you want to figure it
(I've got lots of info on methodology & data if anyone cares to see it)
This is in the ball park of aeroheads posted data for wheel cover savings:
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc.
I realize most vehicles (even S10s) may not see that kind of improvement
but have stock "swirlies" and they are very un-aerodynamic
where I live here in Kansas - there are bunches of S10 with these wheels
they aren't bad wheels for stock - aluminum & only ~15 lbs
for those of you who have not seen what I am talking about I have attached photos
also I have an after pic of the covers on the truck
As for my covers - I'm sure you are desperate to know who makes these aerodynamic wonders....
check out pic 3 - Walmart 16" pizza pans - $2.97 ea.
Concrete
Start where you are - Use what you have - Do what you can.
The Following 5 Users Say Thank You to Concrete For This Useful Post:
coehorn (01-25-2011), HHOTDI (02-05-2011), metaltrades01 (12-19-2011), traveler4466 (06-13-2010), tugboat (05-15-2011)
