Old 08-03-2008, 09:04 PM   This thread is in the EcoModder Project Library | #1 (permalink)
homeworkhome53
homeworkhome53's Avatar
Workride - '07 Aveo5 SVE
90 day: 51.74 mpg (US)
Kill switch accomplished
I found a fuse in a box in the engine compartment marked fuel which I jumpered around with an inline fuse and switch which I mounted beside the manual gear shift. Works fine, but I can still hear my fuel pump running when in the off position, so I went back and looked some more and found a relay that is marked fuel pump in the same compartment. I think what I'm killing is the fuel injectors. When I throw the switch the car continues to run for a few moments. Just long enough to take it out of gear before it loses power. The instrument cluster continues to run and the odometer continues to total which is what I was looking for. The lights stay on which was a biggy for night driving.
homeworkhome53
