Old 02-01-2016, 09:47 PM   #2561 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by e*clipse View Post
Paul, thingstodo -
Is the net current between the AC motor and the battery pack flowing into the battery at all times during regen? If not, it's more of "reverse torque" than pure regen - does it switch modes?
If so, (if it does reverse) what happens with the current near 0 rpm?
E*clipse
The data shows approximately where the energy that the AC controller is regenerating from the AC motor is not enough to run the AC controller, and the High voltage pack begins to use power again. Between 1100 and 1200 rpm. Below 1100 rpm the motor takes power.
First test
https://youtu.be/GWUgdRVXpCs
Second test
https://youtu.be/PQRFHKEAPIU
Log files 18 5, 18 6 plus spreadsheets .. all attached .. as a 2 zip files .. because they are too frigging big.
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (02-01-2016)
