Old 02-14-2016, 12:58 PM   #22 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Originally Posted by pgfpro View Post
WOW!!!
I'm also very interested in how you are going to make the floor pan more rigid?
IMO I would build a tube chassis floor bars and also add pillar foam to the rockers. I would also take some measurements from a stock Prius at the doors aperture (front to rear) and then make some temporary upper bolt in bars to set them to spec.
Very cool project!!!
Glad you like it! Good questions. Kind-of jumping ahead in the story...
First some diagrams:
I have made strategic measured cuts in the Firebird floorpan so that it keys into the Prius V floorpan like a jugsaw puzzle. The transmission tunnel and driver's seat supports will have numerous areas where the two car floorpans are welded together. The Prius V floorpan is unmolested and retains its full strength. The Firebird structure will just add to it. It is easy to see where the white areas protrude into the Firebird's sheetmetal. I am doing a similar thing between the two firewalls and in the rear of the car.
Bill the Engineer
The Following 8 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), BamZipPow (03-04-2016), eco_generator (03-07-2016), HHOTDI (03-03-2016), mcrews (02-14-2016), MetroMPG (02-14-2016), pgfpro (02-14-2016), Xist (02-14-2016)
