I took a stainless steel pipe coupler and cut it in half and welded it to a 1/8 inch thick 2 inch wide flat bar.
I used stainless be cause it welds up a lot better than the iron pipe fittings they sell at the hard ware store.
Iron tends to crack when you weld it.
Reason: change an "n" to a "c"
