Old 01-11-2008, 11:41 PM   #6 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Originally Posted by Lazarus View Post
Rick,
Did you warm up the car and with it running at the RPM you want disconnect it? If not it will show those symptoms. I get the CEL light for low idle about 1 a month. Just use the SG and clear it.
No, it was a cold start, with the car off. I wondered what you meant by a "1000 RPM set" -- good point.
I'm trying to rationalize the ECU's interpretation -- it must use the last input of RPM and IACV voltage as a baseline, and use those for the ECU's current calcs. How did you come across this, by the way? -- interesting idea...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
