Old 08-04-2008, 03:55 PM   #1 (permalink)
pasadena_commut
modifying air flow electrically
I hesitate to introduce this topic, given the almost unlimited potential for snake oil that might result, but here goes anyway.
All of the aerodynamics discussed here, and in fact, pretty much everywhere else, assumes that neither the fluid nor the vehicle carries a significant charge or magnetic field. Normally this is true - but it does not have to be. For instance, charged molecules could be injected into the passing air, and then the flow as a whole redirected using magnetic or electric fields. In practice only a tiny tiny fraction of the air molecules would be charged, but that would likely still be enough to affect the flow as a whole, since the mean free path of an air molecule is very short:
DavidPace.com - Mean Free Path of Air
so that force applied to the few charged molecules would be rapidly transferred to the uncharged as well.
Imagine charged molecules are injected well before the trailing edge of the vehicle. Large electrostatic plates at the back might be able to "focus" the charged flow more inward than it would otherwise go, possibly reducing drag. Indeed, simply charging the air on top of the car positively, and the air under the car negatively, would produce a force to pull the two streams together which would otherwise not be present (this is very much preliminary hand waving, there may well be no pair of oppositely charged atmospheric ions available for this purpose which are safe to inject into the air at the requisite concentrations). Whether any of these approaches ended up being a net win in terms of energy usage would of course depend on how much (if at all) drag was reduced, versus the power needed to generate the charge and maintain the electrostatics or magnets. Of course, none of this is likely to work in the rain.
Some related ideas have been out for a while, although they are usually applied at much higher velocities than are seen on a car. See for instance:
AGT - Plasma Aerodynamics
Will Plasma Revolutionize Aircraft Design
