Old 03-05-2016, 01:34 AM   #11 (permalink)
oil pan 4
Originally Posted by Isaac Zackary View Post
It's below 0°F most all January and February. On the one hand it would be nice to have instant heat.
That is not good if it has LiFePO4 battery. I don't know what YM leafs used them.
Problem with LiFePO4 when you go much below freezing is:
Power output goes into the toilet.
Batteries are permanently damaged if charged when colder than 20'F, I know the leaf has a battery temperature controller, but the car will be spending a good amount of time and energy keeping the battery warmed.
Knowing that, when you plug in the battery will have to warm up some before it can start charging.
As far as I can tell the heat kills those batteries more than the cold, it was developed in japan where they understand what cold is. The batteries I know of that suffered damage were mostly in Arizona.
I live in NM and pull my LiFePO4 starting battery out at night when its cold here.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Isaac Zackary (03-05-2016), Xist (03-08-2016)
