Old 04-01-2016, 09:14 PM   #2731 (permalink)
ale0502
Ale Madeo
ale0502's Avatar
Smile change of motor
Seeing those numbers, I decided that I have to change the motor.
I will use one 4-pole 2.2kW. In which can lower the operating voltage to 380/4 = 95V, which is much closer to the 85Vrms that I have with my 120V batterypack.
In addition, 1400rpm at 50Hz are 200Hz 5600rpm what is not too dangerous like well explain "thingstodo".
I will continue moving forward with the construction of the controller and modifies my new motor.
I will soon come back with questions.
Thank you Paul and thingstodo !!
Los que dicen que es imposible, no deberían molestar a los que lo están intentando...
