Originally Posted by Yoshi
Do you have any clue how much the "Injector DelayuS" value would be?
No clue, I'm guessing it is a small amount of time. But I never even contemplated HDI till yesterday, have not hunted down injector specs, and don't know how long it takes to squirt out a milligram at unknown pressure at unknown flow rate. That's a measure it and see problem IMHO.
Originally Posted by ecoxantia
It seems to me that to use the MPGuino on this engine there are too many variables to make it work
The atmega in the
mpguino is most certainly capable of performing accurate fuel consumption monitoring on an HDI with the right programming strategy. It may come back to monitoring the fuel pressure like you said, and applying that and the injector open time to a 2d map formula. It isn't that there are too many variables though, technically speaking.
But it might not be a very practical exercise if a $160
scangauge will tell you what you want to know. You would have to really want the additional precision an injection monitor can provide to go through the effort.
