You could also build some sort of flow meter that you put in the fuel line. I know the guys that are doing the "pre-fuel injection" stuff have been looking at a solution doing something like that. The nice thing is that if you can get a flow meter, it should work on any vehicle, and you wouldn't have all the complexities. It may not be as accurate, but it would be doable in the short term.
