Old 08-06-2008, 01:06 AM   #7 (permalink)
Concrete
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Re. the cruise control - did you set it once and leave it "on" for all A & B runs, and just cancel it with the brake?
yes, the whole test is "on the fly"
when I enter and leave the course - the only thing I touch is the scan gauge
I found that any other influences created too much error - even a brake tap
everything is setup and in place at least ~1/2 mile before I start taking data
it helps the ECU settle in to cruise
If I had made the pre-run longer - I probably would have fewer asterisks
but it took long enough as it was
I haven't run standard deviation calculations ( I have an aversion to statistics )
but I have gone this far - I guess I should dust the brain cells off and just do it
Concrete
Start where you are - Use what you have - Do what you can.
