Old 08-06-2008, 02:11 PM   #249 (permalink)
rcpmac
Originally Posted by instarx View Post
J there was a factory option for Pontiac GTOs that allowed belt-driven accessories to be turned off from a switch in the dash. It used an electric clutch to disconnected everything belt-driven, including the fan.
This would be the same as a pulley clutch on a typical automotive AC compressor. Shouldn't be hard to adapt one... or should it...?
In any event, does anyone have data on how much load is created when the alternator is spinning but with out electrical load?
And perhaps the easiest solution is putting a switch on the field windings.
