Old 05-18-2016, 09:58 PM   #3 (permalink)
ldjessee00
The Leaf - '17 Nissan Leaf SL
Outback - '16 Subaru Outback
Vaquero - '20 Kawasaki Vulcan 1700 Vaquero ABS
The problem comes from the engine and transmission sharing the same oil, so the oil is 'worked' harder than just oil used in an engine alone.
I am not saying you could not possibly get better FE from a change in viscosity, but you would have to monitor how much the engine and transmission are handling the change.
There is lots of research you could probably do, knowing that...
