Old 06-10-2016, 07:57 PM   #6 (permalink)
ChopStix
Primer is still paint!
ChopStix's Avatar
Here's a list of available mods for Chevy Astro Vans, 1996-2005 4.3L ENGINE.
All information I believe to be correct.
If in doubt, always contact manufacturer. Use at own risk.
AIR FILTER OEM REPLACEMENTS
1) Holley Powershot,#221-1
2) K&N Filtercharger, #33-2225
3) Jet Performance, #4122
4) Accel Kool Blue, #KP2348
AIR INTAKE KITS
1) Volant, #25743
2) JET Performance, #63290
MASS AIR FLOW SENSOR
1) Granatelli, #350116 (normal intake)
2) Granatelli, #350116C (aftermarket intake)
Throttle Body Spacer
1) Jet #62107
2) Transdapt #2564
COMPUTER REPROGRAMMING
1) Jet Power Control Module | Stage 1 #20015
2) Jet Power Control Module | Stage 2 #20015S
3) Jet Performance Programmer #15024
1) Hypertech PP3, #390202 (1996-1999) #360202
2) Hypertech PP3, #30001 (2000) #30024
3) Hypertech PP3, #30008 (2001) #30023
4) Hypertech PP3, #30012 (2002) #30012
5) Hypertech PP3, #30019 (2003) #30019
6) Hypertech PP3, #30022 (2004-2005)
7) Jet Performance, #2004 (stage 1)
8) Jet Performance, #2004S (stage 2)
9) Superchips GM Max Tuner, #2565 (98-00), #2575 (01-02)
THERMOSTATS
1) Hypertec 160 temp, #1013
2) Jet Performance 180 temp, #10171
3) Duralast 195 temp, #15119
4) Stant 195 temp, #45119
IGNITION ITEMS MSD
1) 6 Series, #6420 (6AL)
2) Wires, #32389 (98-00), #31649 (90-97)
3) Coil, #8231
IGNITION ITEMS ACCEL
1) Truck tune-up kit, #TST-1 (includes plugs, cap, rotor, wires – 9000 series)
2) Wires, #9044
3) Coil, #140024
4) Cap, #120142
5) Rotor, #130141
EGR MOD FROM MDW PERFORMANCE
1) EGR Restrictor Plates, #10GM9602, $74.99
2) EGR Restrictor, #44GM9602, $48.99
INLET AIR TEMPERATURE SENSOR RELOCATOR/ SIMULATOR
1)Jet Performance, #61620
2) Radio Shack Resistor 4.7K Ohm, #271-1330
THROTTLE POSITION SENSOR CONTROLLER
1) Casper's Electronics, #102017
SUPERCHARGING
1) Powerdyne, #K10526-101
UNDERDRIVE PULLEYS
1) March, #4460 (2pc)
2) ASP, #841001 (2pc), #841051 (3pc)
3) JET Performance, #90105 (2pc)
belt for Jet pulleys - 060935
ROCKER ARMS
1) SLP Engineering 1.6, self align type
SHOCKS/ SUSPENSION
1) Edelbrock IAS, AWD (1995-2005) – Front #3303, Rear #3438
2WD (1985-2005) – Front #3338, Rear #3438
2) Bilstein B6 Performance Series Shocks Front (1985-2005) 2WD #24-011044
Rear (1985-2005) 2WD and AWD #24-010474
EXHAUST SYSTEMS
1) Gibson, Dual Sport, #5607 (Aluminized), #65607 (Stainless)(2000-2005)
2) Gibson, Extreme Dual Sport, #5609 (Aluminized), #65609 (Stainless)(2000-2005)
3) Gibson, Split Rear, #5608 (Aluminized), #65608 (Stainless)(2000-2005)
4) Gibson, Swept-Side, #315560 (Aluminized), #615560 (Stainless)(2000-2005)
5) Gibson, Swept-Side #315500 (Aluminized), #615500 (Stainless)(1996-1999)
6) Gibson, Swept-Side, #315553 (Aluminized), #615553 (Stainless)(1995)
INTERIOR ACCESSORIES
1) Autometer Gauge Pods, #15123 (Single, A-Pillar for 2-1/16” gauge), #15122 (Dual, A-Pillar for 2-1/16” gauge)(1996-2005)
EXTERIOR ACCESSORIES
1) Lebra, Hood Protector, #45111-01
2) Lebra, Front End Mask, #55535-01
3) Auto Ventshade (AVS), Ventvisor (Plastic), 92006
4) Auto Ventshade (AVS), Ventshade (Metal), 12215 (Stainless) and 32015 (Black)
5) Auto Ventshade (AVS), AeroVisor (Plastic, wider at mirror area), #95015
6) AVS, Bugflector (coverage stops at ends of hood), #22001 (Smoke) or 22001-C (Clear)
7) AVS, Bugflector II (coverage wraps around corners of fenders), #24616 (Smoke) or 24616-C (Clear)
8) AVS, Headlight Covers, #41535 (4 light – 4 piece)
9) Kleen Wheels, Brake Dust Covers, #1507 (15”-5 spoke wheels, stock)
10) APC, Clear Taillights, #404113TLR (1985-2005)
11) APC, Diamond Headlights, #403662HLD (1995-2005, composite style)
12) IPCW, Clear Taillights, #CWTCE314C (1985-2005)
13) IPCW, Diamond Headlight Corners, #CWCCE19 (1995-2005)
14) IPCW, Projector Headlights, #CWCCE20 (1995-2005)
GAS CAP
1) Stant, #10836
1) Stant Locking, #10506
BELLTECH SUSPENSION LOWERING KITS
1) 3.0 Front, 3.5 Rear, #770SP
2) 2.0 Front, 3.5 Rear, #768SP
3) 2.5 Front, 3.5 Rear, #769SP
4) 2.5 Front, 2.5 Rear, #772SP
REESE MULTI-FIT RECEIVER HITCHES
1) Class I/II 1 1/4" square #88001
2) Class I/II 1 1/4" square Invisi-Hitch #06227
3) Class III 2" #51029
4) Class III/IV 2" #37152
5) Class III/IV Premium 2" #37042
6) Class III/IV Professional 2" #44010
