Old 06-11-2016, 05:16 PM   #10 (permalink)
ChopStix
Primer is still paint!
ChopStix's Avatar
Low temperature will lower fuel economy and increase engine wear. EGR restrictor will likely lower fuel economy. Cold air intake will also lower fuel economy. Air intake temperature simulators are guaranteed to lower fuel economy, they trick the engine into believing the air is cooler than it really is, encouraging the ECU to add more fuel.
Its a parts availability resource, not a parts suggestion. And its a work in progress so I'll be adding more info as free time allows.
