Thread: VSS problem
Old 06-13-2016, 12:35 PM   #7 (permalink)
mirkwood
Originally Posted by t vago View Post
26280 is really, really high. You will want to place a frequency divider between your VSS signal output and the MPGuino.
Something like this:
Yah, they're the same. I was going off an early MPGuino code version. What version of MPGuino code do you have?
Hehe yeah okay, really really high.
Yeah, I just noticed this guy had similar problem http://ecomodder.com/forum/showthrea...mit-29787.html
and he was to do a divider aswell, but no conclusion.
Hmm... is this something that can be bought somewhere pre-built?, I tried to do a search, but either i am not using the right words, or then it is rare.
If i am to solder myself then i need a really detailed plan. Soldering no problem, but schematics not my strongest side.
In another thread on a Alfa romeo site i found this, but it is an more expensive option.
Universal Speedometer Signal Interface
Where do i see the code version?, on the unit itself?.
Thanks again .
