Old 08-07-2008, 07:48 AM   #4 (permalink)
gascort
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
Originally Posted by adrive7 View Post
Something I have wondered about this is Max A/C means the compressor does not work as hard, but it requires another fan to kick on (which is considerably louder than the normal fan, but probably irrelevant) which requires a larger load on the alternator.
So, which wins out? A more frequent but intermittent A/C compressor or a constant draw fan? I don't know the answer.
Coyote X is correct; the same fan is running, but with an interior intake open. This makes it more noisy and also blows harder since there's less resistance on the fan. I bet the blower motor uses the same amount of electricity on fresh or recirculating settings.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
