Old 06-26-2016, 05:24 PM   #2 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
My 1991 Honda does it. I think most fuel-injected cars should do it. An easy test that works with a manual might work with an auto too. Manually shift into 1st gear and accelerate from a stop up to 3000 RPM. Take your foot off the gas and you should feel the injectors come back on around 1000-1500 RPM. My car will buck a little when this happens.
And idling in neutral will be more efficient if you're not trying to slow down. But yes, keep it in gear if you want to slow down.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
parablooper (06-26-2016)
