Old 06-30-2016, 11:12 AM   #7 (permalink)
mikesheiman
Originally Posted by Grant-53 View Post
The taper resembles some of the human powered vehicle shells. First tuft test the shape you have with and without a rear deck wing. Dr. Joseph Katz has some good books that are less expensive than Hucho's grand book. My suggestion is to use a shape based on a 5:1 airfoil with a Kamm tail at 0.75 the length.
Will do and thank you!
The Kamm tail/desk wing seems to be an obvious mod to test. Will look into/read-up on Katz.
When you say 0.75 the length, do you mean 75% of a full teardrop shaped rear end (seems a bit long), or % of what, exactly?
The real mystery to me is how much should I taper the rear...given I'm starting with flat sides at about 70 inches width, what should my width be about, say, 3 feet back?
Or should I just try cutting off the back end taper entirely (straight down, forming a Kammback on the sides of the rear wheel) and just leave the rear wheel fairing sticking out of the back area with its further extended Kammback?
