Old 07-23-2016, 08:21 PM   #58 (permalink)
funkhoss
The Little Car - '00 Chevrolet Metro
90 day: 91.08 mpg (US)
The Big Car - '94 Chevrolet Caprice Wagon
90 day: 44.9 mpg (US)
Might it be possible to terminate the brake line in a master cylinder and have a slave on each axle with a removable physical link? I'm not sure whether it would go before or after the flexible section. Maybe the slave could mount on a suspension bracket.
To save bleeding the brakes.
As I described in my initial post, I'm going to put a quick disconnect on the line that goes to the rear brakes (there's only one line that feeds both brakes). That quick disconnect coupling will let me swap axles without having to bleed them each time.
I'm also going to make a bracket that will let me do the same thing with the parking brake cables--I'll be able to just bolt them up without having to readjust.
The Following User Says Thank You to funkhoss For This Useful Post:
freebeard (07-24-2016)
