Old 01-13-2008, 09:42 AM   #9 (permalink)
Lazarus
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
Originally Posted by RH77 View Post
Just after that post last night, I went out and followed the instructions as indicated. No luck. Even at normal operating temp, revved up to 1000 RPM, pulled the IACV, and ka-put.
The ECU is just too involved in the process and is debilitated without it. The next try is to wire it to a switch in the cabin, to have more control over it. I still have that toggle installed from the cylinder deactivation experiment 2 years ago
The lowest I could get the engine to turn was 400 RPM. Does anyone know if this is too low to pump vital fluids (tranny, oil, etc.)??? I can coast-down in top gear in "D" and it just gently dies after 400 R's, or if I downshift to 3rd, it comes back alive (same with feathering of the throttle). Maybe the switch will allow some more creative control over the process.
Side note: it seems to idle fine at 400-500 RPM -- could this be a fuel saver? I tried the A/C and maxed-out the electrical load and it was fine -- no stalls.
RH77
P.S. Thanks for moving the thread -- clogging up the EBH info, off-topic and all
Does the data logger you have record oil pressure? See who low it is when you're at 500 rpm. I guess when it's that low no idiot lights?
"Judge a person by their questions rather than their answers."
